*** SOLVED *** Does not work WYSIWYG Web Builder 14
Alex15963
Post by Alex15963 » Tue Jul 17, 2018 7:51 am
Disappeared the animation tabs and events on the properties object. They are not found anywhere. Neither in the figure, nor in text, image, etc. On the property page. Absolutely not. No animation, no events. On tab "page", many tabs do not. They just disappeared. I tried to reinstall the program is the same. When I installed the program on another computer and the program requested an activation key - it all became fine. But on my computer the program is reinstalled without requesting an activation key. How to completely remove program to install it with an activation key? Or how can to fix the program? Thank you. Sorry for the bad english
Re: Does not work WYSIWYG Web Builder 14
Post by Pablo » Tue Jul 17, 2018 7:57 am
I think you have enabled 'Easy Mode'. This will hide advanced features.
Alex15963
Post by Alex15963 » Tue Jul 17, 2018 8:04 am
Yes! Thank you!
