Sliders and blocks
IanRob
Re: Sliders and blocks
Post by IanRob » Fri Aug 03, 2018 2:08 pm
to my knowledge I have not selected any mode
So whwere do I find the switch for easy mode? I cannot find it in options
Also, I have no slider in the Jquery/bootstrap menu
Post by Pablo » Fri Aug 03, 2018 2:28 pm
IanRob
Post by IanRob » Fri Aug 03, 2018 2:52 pm
Thank you
Switching out of easy mode has indeed solved both the blocking and slider problems
I now have two other problems, which I can either state here or open a new thread.
If it is OK to state them here they are
1 I want the main html tag to look like:
<html manifest="quiz.appcache">
But can see no option to achieve this
2 Clicking the "include viewprt" button does not seem to have any effect. I was assuming that it should automatically include a tag such as
<meta name="viewport" content="width=device-width, initial-scale=1.0">
But ist does not create that tag
Post by Pablo » Fri Aug 03, 2018 2:56 pm
I'm sorry, there is no option for this.
It will only be added if the page has breakpoints or layout grids.
Post by BaconFries » Fri Aug 03, 2018 2:57 pm
Pablo can't this be inserted by using the HTML Object using inside HTML tag?
IanRob
Post by IanRob » Fri Aug 03, 2018 3:07 pm
yes, thank you BaconFries.
However, that option (for some weird reason) is not visible with the mode in "Easy" That was my problem
By the way, thank you for also reponding to my earlier comment about loading images.
If you have anything influence with the way the forum programmes operates, may I make a suggestion
On my personal preferences, I have the "notify by email of post replies". However, when I start a new thread, I have to remeber to tick that box because, despite my preferences, it defaults unticked
Also I have not yet managed to get "save a draft" to work
Thanks again for your assistance
Post by Pablo » Fri Aug 03, 2018 3:19 pm
This is not a 'weird reason'. This is intentional, because Easy Mode hide advanced features.
Yes! You are correct, this can be added via the HTML object.
IanRob
Post by IanRob » Fri Aug 03, 2018 4:06 pm
Hi Pablo and BaconFries
"can't this be inserted by using the HTML Object using inside HTML tag?"
Thanks for this
However, I am a novice
can you explain in simple terms which menu buttons I use to do this - Thanks
Post by BaconFries » Fri Aug 03, 2018 4:26 pm
Drag'n'Drop the HTML Object to page open add the following
manifest="quiz.appcache" in HTML in the drop down select between<html>
See the following:
http://www.wysiwygwebbuilder.com/add_html.html
IanRob
Post by IanRob » Fri Aug 03, 2018 4:38 pm
Brilliant
Thank you for that
and thank you Pablo for your patience
Ian
