Placing Objetcs in Layer (They not stay in wanted position when previewing/publishing)
rodmorale
Post by rodmorale » Thu Aug 09, 2018 8:16 pm
Hi there.
I'm a bit new using this software.
I'm working with Layers. In the first one, for example, I placed an Image, a Text, a Line and another text. I want them in a specific position (not only centering horizontally or vertically in the layer).
For example, I would like, when publishing, the Line placed between Text 1 and Text 2 stays at the same distance of both Texts.
I'll post two images, one in the editing view and one in preview in browser.
Thank you VERY much!
Re: Placing Objetcs in Layer (They not stay in wanted position when previewing/publishing)
Post by Pablo » Fri Aug 10, 2018 6:33 am
Can yo please share your project file?
rodmorale
Post by rodmorale » Fri Aug 10, 2018 9:21 am
Hi.
I'm not sure how to do that.
I've uploaded it.
http://www.mediafire.com/file/lm2x5yk2h ... 283%29.rar
Post by Pablo » Fri Aug 10, 2018 10:17 am
I'm sorry, I cannot open your file.
Can you please share it in standard zip format?
Also describe exactly where I need to look in your project.
rodmorale
Post by rodmorale » Fri Aug 10, 2018 11:20 am
There you are, in ZIP format.
http://www.mediafire.com/file/97t5mbn4k ... 283%29.zip
In the working space, objects are placed inside de layer within a specific distance between them. Once I preview or publish, they "move" like I showed in the images of the first post.
Thank you so much!
Post by Pablo » Fri Aug 10, 2018 12:36 pm
I think you will need to replace the line with standard horizontal line.
rodmorale
Post by rodmorale » Fri Aug 10, 2018 1:01 pm
Nope, does not work either. :(
Post by Pablo » Fri Aug 10, 2018 1:03 pm
Really? I have tried it myself and it works correct.
rodmorale
Post by rodmorale » Fri Aug 10, 2018 1:13 pm
Here you have the archive.
Happens with the line under "WE ARE EBSTUDIO" and with the other one too.
http://www.mediafire.com/file/ka98jyhiy ... 9.zip/file
Post by Pablo » Fri Aug 10, 2018 2:10 pm
I do not think the line is the problem. I think the text is rendered a little bit taller because each browser renders text differently.
Note that this only applies to 'fixed' page layout.
For floating layouts this will not be an issue.
Related FAQ:
viewtopic.php?f=10&t=34318
rodmorale
Post by rodmorale » Fri Aug 10, 2018 2:32 pm
How do I change the page layout then?
