button help
sentinel
button help
Post by sentinel » Sun Aug 19, 2018 4:14 pm
hi all
i was not sure where to open this topic
so brief explanation i am trying to add some buttons for signing in with socials like google and i have found these buttons that i want to use
https://lipis.github.io/bootstrap-social/
how posable is it to add the buttons i tried a few thing but nothing worked i know this may be asking a lot but can someone give me an example on how to do it as i am learning WYSIWYG web builder
yes i do understand that WYSIWYG web builder is a generator and not a editor and that this may not be posable at all
i am also a little curious on why there is no default log in with socials like this built into WYSIWYG web builder
BUT if i refer to it as a editor what i mean is visual editor NOT html editor
Re: button help
Post by Pablo » Sun Aug 19, 2018 4:59 pm
These button require bootstrap, so you will have to install this on the server before you can use them.
I think this is overkill for just a few buttons...
Also note that the buttons not actually do anything. They are just buttons with an image.
You can easily duplicate this with the built-in WWB tools.
For example, see the social icons in this template:
http://www.wysiwygwebbuilder.com/suppor ... wyork.html
sentinel
Re: button help
Post by sentinel » Sun Aug 19, 2018 6:46 pm
hi pablo
i was also looking into the circle progress bar listed in https://stackoverflow.com/questions/453 ... ogress-bar
that looks like it uses bootstrap as well and i haven't found out how to do that with wb14 either so i was going to try and use similar one to that because i am working on a status page that pulls information from a mysql database
and i want people to be able to login with say google to view there status please note that i will be using oauth2.0 for logins
Re: button help
Post by Pablo » Sun Aug 19, 2018 8:34 pm
I'm sorry. I cannot help you with bootstrap integration or other programming related questions becuase this generally takes a lot of time and it is not really specific to WWB.
But maybe this extension will be helpful?
http://wysiwygwebbuilder.com/circleprogressbar.html
sentinel
Re: button help
Post by sentinel » Sun Aug 26, 2018 2:02 pm
hi pablo
thank you for linking me to that extension it is going to be helpful as long as it keeps playing well with flex grids which have already been a very wired experience(should have made a video i would have made good use of the benny hill theme song)
