Will this work with WYSIWYG Web Builder
pflournoy
Post by pflournoy » Thu Sep 06, 2018 10:47 pm
I have been with WYSIWYG for seven years and have loved every new addition. However, I am having an issue that I need and I can't find a WYSIWYG extension. I have a website www.privateschoolsports.com and I need to add stats and league standings/power rankings.
Right now I have rankings like this
http://www.privateschoolsports.com/boys ... k2fbd3.php
And stats like this
http://www.privateschoolsports.com/boys ... ng2017.php
The standings are okay but I need stats like this battering average one
http://demo.themeboy.com/sportspress/marquee/baseball
I don't want to go to W**d***ss so I am trying to find another solution. Will this widget work on WYSIWYG or do you know of to make sports tables like these.
https://www.themeboy.com/sportspress-pro/
Re: Will this work with WYSIWYG Web Builder
Post by BaconFries » Thu Sep 06, 2018 10:56 pm
There is no extension for this sorry, what your asking is very specific to your needs and would require a custom solution. To answer you on the plug-in shown no you cannot use any w**dpr**s plug-ins in WB.
pflournoy
Post by pflournoy » Thu Sep 06, 2018 11:09 pm
Is there someone I can pay to build one for me in WYSIWYG?
Post by BaconFries » Thu Sep 06, 2018 11:18 pm
As the subject matter is what is seen as 'Off Topic' you can post in the Off Topic Section where others can read and hopefully you will get a reply. A similar question to your own was asked at League Tables see my reply as a way to maybe implement. As I mention in the 'League Table' link, if you are familiar with working with spreadsheets you can go down that route. I came across this YouTube video on how to write use for a Little League but it maybe help you.
https://youtu.be/HCmsJAfe6t8
petertj
Post by petertj » Fri Oct 05, 2018 3:11 pm
Interesting suggestion Baconfries.
I have taken a look at the rotating list spreadsheet and see that the process involves using a number of Excel functions to change the order of a list in a specified way.
Are you suggesting that these functions could be duplicated within the Extension Builder?
Filemaker is particularly good at this kind of jiggery pokery.
Peter
