missing option in navigation menu wwb14
maxime
Post by maxime » Fri Sep 14, 2018 9:44 pm
in the other version exemple : wwb version 12 there is an option in different menu exemple : tab menu there is an option where we can choose to use this menu for the CMS
in the wwb14 versdon we do not have those choice !
CMS
Use this menu for CMS
Enable this option to use the menu with the CMS tools. Instead of a static menu, the links will be dynamically generated based on the CMS database.
Note that this only works when the page has been published!
i do not have this option in wwb14 !
Re: missing option in navigation menu wwb14
Post by Pablo » Sat Sep 15, 2018 6:13 am
Please disable 'Easy Mode'. This will hide advanced options.
maxime
Post by maxime » Sat Sep 15, 2018 1:40 pm
ok thank you . everithyng is fine now !
