Best image folder practice
Lasa
Post by Lasa » Thu Oct 11, 2018 12:52 am
What would be best image folder practice. It seems WYSIWG Web Builder makes on image folder and throws everything in it.
Is there a way to have it save it in some preset orderly manor? All the NIVO slider images in one folder, food images in another folder, etc.
If not I can probably group them it via prefixes of some sort.
Is there a reason that all the images get put in one folder?
Thanks,
Lasa
Re: Best image folder practice
Post by Pablo » Thu Oct 11, 2018 6:14 am
The target folder for specific files types can be configured in Tools->Options->File & Folders
You can create sub folders in the Site Manager.
If you create a folder for pages with NIVO slider then that folder will have its own images folder.
Lasa
Post by Lasa » Thu Oct 11, 2018 12:39 pm
Thanks for the quick answer.
I was able to specify the file & Folders.. was able to make a sub folder in site manager.
How do I have all the nivo image go in the nivo folder? they seem to go into the image folder.
Sorry, but I'm very new to web Builder.
Cheers
Post by Pablo » Thu Oct 11, 2018 12:51 pm
Move the page with the nivo slider in the sub folder.
Note that the images will still go in the 'images' folder ,unless you have specified a different folder.
Or you can also use absolute paths.
Lasa
Post by Lasa » Thu Oct 11, 2018 1:22 pm
Awesome! Thanks!
