Inline Frame won't load web page
ptlycldy
Post by ptlycldy » Sat Oct 13, 2018 3:05 pm
I have a page in my web site that used to work that allows you to check "Are you registered to vote?" on the Texas Secretary of State page. The SOS page must have changed or the inline frame code may have changed. My page with an inline frame links to:
https://teamrv-mvp.sos.texas.gov/MVP/mvp.do
but will not load. I have tested other links to outside pages and they all work. What is different about the SOS page that will not work with an inline frame? The SOS page will work with a pop up window or load in a separate window.
Any ideas on how to get it to load into an inline frame would really be appreciated.
Re: Inline Frame won't load web page
Post by Pablo » Sat Oct 13, 2018 3:16 pm
Some services do not allow you to use their content inside an inline frame.
or maybe you are trying to display a 'https' page inside a 'http' page?
Note that this is unrelated to WWB.
ptlycldy
Post by ptlycldy » Sat Oct 13, 2018 3:31 pm
Thanks Pablo --
I didn't pick up on the https/http conflict. I'll try to change my page and site to be secure.
Thanks again.
