Insert link with 'Carousel controlled by Photo Gallery' Block
Beth
Post by Beth » Sun Oct 14, 2018 2:32 pm
Is there any way to create a hyperlink to a page in the site from the big picture when using the 'Carousel controlled by Photo Gallery' block? If so, that would be grand. I've tried the bookmark, events and direct text approach but can't seem to figure it out.
Thanks in advance.
Re: Insert link with 'Carousel controlled by Photo Gallery' Block
Post by Pablo » Sun Oct 14, 2018 3:10 pm
You cannot add a link to the image, because it's a background image.
But you can add a linkable object (like a transparent shape or image) inside the Carousel slide to add a link.
Or another commonly used option is to add a 'more info' button with link.
Beth
Post by Beth » Sun Oct 14, 2018 4:49 pm
Thanks Pablo. That will do fine. That's one thing that I didn't try. :D
