Lightbox functions in preview, but once uploaded no.
Smee
Post by Smee » Mon Oct 15, 2018 4:00 pm
I am working on a site that will use dozens of lightboxes to display furniture.
While in preview mode, they work perfectly. Once uploaded to site, the lightboxes do not work at all. Clicking on the images opens them to fill the browser window. I have to press backspace or click the back button to return to the site.
Just getting started, so maybe something has changed in the newer versions of WWB. Thanks.
Re: Lightbox functions in preview, but once uploaded no.
Post by Pablo » Mon Oct 15, 2018 4:02 pm
Did you upload all files?
Did you make sure all image file names are web-safe?
Related FAQ:
viewtopic.php?f=10&t=131
Smee
Post by Smee » Mon Oct 15, 2018 5:19 pm
FIles uploaded to server. Websafe names chosen.
Uploaded page: http://www.gammels.com/liv_spec.html
Post by Pablo » Mon Oct 15, 2018 5:38 pm
For the first two images you have used different lightboxes (fancybox and slimbox).
The third image does not have a lightbox.
I recommend to use the same lightbox for all images. The lightboxes are third party scripts so they may not be compatible with each other.
Smee
Post by Smee » Mon Oct 15, 2018 6:26 pm
Thanks. The reason that there were different lightboxes is I was trying to determine why each one didn't work.
Maybe it's a firefox problem, worked with edge regardless of lightbox selected.
