Responsive blog
janez72
Responsive blog
Post by janez72 » Thu Oct 18, 2018 10:03 am
I have a blog inside layout grid.
The blog height is always fixed, cannot it be flexible, responsive?
Re: Responsive blog
Post by BaconFries » Thu Oct 18, 2018 10:16 am
If you are referring to the PHP Blog extension then sorry it is not responsive, it was developed and released before RWD became the norm. As a workaround you can insert the blog page into a iframe then place in a Layout Grid
janez72
Re: Responsive blog
Post by janez72 » Thu Oct 18, 2018 10:19 am
No, not the php.
Just the plain Blog.
The height of layout grid doesn't adjust to blog's height.
Re: Responsive blog
Post by Pablo » Thu Oct 18, 2018 10:59 am
The built-in blog is responsive/flexible. By default, the height is the sum of all articles, but if you enable the scrolbars then you can set the height manually.
janez72
Re: Responsive blog
Post by janez72 » Thu Oct 18, 2018 11:34 am
Yes, the default should be sum of all articles.
But it's not. The height is just the one, I set manually.
Blog is not responding to it's data.
Tried all possible combinations. Within and outside a layout grid.
Re: Responsive blog
Post by Pablo » Thu Oct 18, 2018 12:23 pm
Did you preview/publish the page?
I assume that you are using the latest update?
janez72
Re: Responsive blog
Post by janez72 » Thu Oct 18, 2018 12:57 pm
I previewed it, can't publish, until it's ok.
Yes, latest update.
I checked blog's .html - it has the blog height fixed (190px in my case).
Re: Responsive blog
Post by Pablo » Thu Oct 18, 2018 1:22 pm
What is the URL?
or where can I download the project file?
viewtopic.php?f=10&t=82134
janez72
Re: Responsive blog
Post by janez72 » Thu Oct 18, 2018 1:31 pm
Re: Responsive blog
Post by Pablo » Thu Oct 18, 2018 2:12 pm
It looks like you are using pagination, in that case the blog will have a fixed height.
To make the blog fully responsive it please use the default settings.
janez72
Re: Responsive blog
Post by janez72 » Thu Oct 18, 2018 2:33 pm
Pagination removed, nothing happened.
All values are now default.
Re: Responsive blog
Post by Pablo » Thu Oct 18, 2018 3:19 pm
The blog is not inside a layout grid, so then it's not flexible.
janez72
Re: Responsive blog
Post by janez72 » Thu Oct 18, 2018 4:01 pm
Yeah, it's working.
But only in layout grid, items per page set to 0 and with carousel set to OFF.
I wanted to have it in 1 slide per page mode and in carousel.
Re: Responsive blog
Post by Pablo » Thu Oct 18, 2018 4:18 pm
The blog is only responsive when it's inside a Layout grid otherwise it will be fixed (absolute positioned).
If you enable pagination or the carousel then the behavior of the blog is controlled by a script.
