Events move more like a slideTo
Lasa
Post by Lasa » Mon Oct 22, 2018 1:08 pm
I was wondering if there is a way, within WB options, to control the speed of "move" in events?
If I try and slide a object to another position with the "move" in events... it simply appears at the new coordinates.
I'm probably using the wrong events?
Cheers,
Lasa
Re: Events move more like a slideTo
Post by Pablo » Mon Oct 22, 2018 1:18 pm
If you use 'animate' instead of 'move' then you can specify the duration.
Lasa
Post by Lasa » Mon Oct 22, 2018 1:45 pm
Thanks for the quick reply.
Got it, "animate (javascript)" allows for end coordinate and speed.
Thanks,
Lasa
