Image vs. Picture
Beth
Image vs. Picture
Post by Beth » Sat Nov 24, 2018 6:24 pm
I know that this is a silly basic question, but I do not find the answer elsewhere. What is that difference between a "PICTURE'" and and "IMAGE" in WYSIWYG builder?
I see that they each have some of the same and some differing properties. Is there a guide to explain which is better for certain uses vs. the other?
Thanks for any help.
Re: Image vs. Picture
Post by Pablo » Sat Nov 24, 2018 6:27 pm
Maybe this will be helpful?
http://wysiwygwebbuilder.com/picture.html
Beth
Post by Beth » Sat Nov 24, 2018 7:02 pm
Thanks for that Pablo. Yes, I have already read that and it's not much help because it doesn't tell you how to use it.
If that's the only benefit, I guess that I'll stick with the "IMAGE" object and manually resize as needed.
Post by Pablo » Sat Nov 24, 2018 9:18 pm
