Created zip backup
steveKersh
Created zip backup
Post by steveKersh » Mon Apr 15, 2019 2:58 am
I have one of my sites that when I create a zip backup of the site and then try to open zip I get an error message that the Compressed (zipped) folder is invalid. I have tried re-saving the project as new project but I get the same results. I have several other projects that all save fine. Anyone have any suggestions?
Re: Created zip backup
Post by Pablo » Mon Apr 15, 2019 6:01 am
There are no known issues with zip. But it may be related to the file name or files used by the project.
To be able to help you I need a copy of the project and project folder.
steveKersh
Post by steveKersh » Mon Apr 15, 2019 11:16 am
Pablo, how do I can I send you a copy of project and project folder? As a note I did create a manual zip using Windows 10 zip function and it worked. Should I attach that zip here?
Post by Pablo » Mon Apr 15, 2019 11:24 am
Upload the file to your website or file sharing service and post the link.
I assume you are using the latest update (14.3.3)?
steveKersh
Post by steveKersh » Mon Apr 15, 2019 11:34 am
Thank you Pablo. I will get it uploaded and send the link when done. My internet service is not the fastest so it will take some time.
Yes I am using version 14.3.3.
steveKersh
Post by steveKersh » Mon Apr 15, 2019 4:51 pm
Pablo,
Here is the link: https://drive.google.com/drive/folders/ ... sp=sharing
Thank you for any assistance you can be.
Post by Pablo » Mon Apr 15, 2019 5:21 pm
I think the problem is related the size of the project and images. On my computer the total size is bigger than 2GB. if you are using the 32bit version then the maximum size of a zip file is 2GB.
I strongly recommend to resize the images before adding them to your website. Not only will this make your website faster, but it will also be easier to backup.
Also note that many errors in the files names. For example, names with spaces or names that start with a number.
See this related FAQ:
viewtopic.php?f=10&t=131
steveKersh
Post by steveKersh » Mon Apr 15, 2019 5:53 pm
Thank you Pablo. I will take a look at making the changes.
Did your suggestions and it did the trick. Thank You so much.
