ID conflict
spoon
ID conflict
Post by spoon » Sun May 19, 2019 9:46 am
Hello, there was a problem with loading content from one page to another. On page 2 there is a text, id = "wb_uid" is automatically assigned to it, when I load the data from page 2 to page 1 then a conflict id = "wb_uid" occurs. What should I do?
Re: ID conflict
Post by Pablo » Sun May 19, 2019 9:58 am
This ID is automatically generated when you add breakpoints, and 'keep inline styles is' disabled.
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 10:08 am
Re: ID conflict
Post by Pablo » Sun May 19, 2019 10:29 am
To be able to help you I need an example project.
Related FAQ:
Also, I need to know exactly where to look to see the problem.
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 10:45 am
Re: ID conflict
Post by Pablo » Sun May 19, 2019 11:19 am
What is the exact problem? Is there an error?
And what do I need to do to see the error?
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 11:38 am
Re: ID conflict
Post by Pablo » Sun May 19, 2019 11:57 am
These IDs are generated because you have enabled the option
Optimize inline styles (move inline styles to the style sheet)
in Tools -> Options -> HTML
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 12:06 pm
But then the styles are written in the html markup. This is not good.
<span style = "color: # 000000; font-family: 'Lucida Console'; font-size: 13px;"> Trend PD / 39 </ span>
Re: ID conflict
Post by Pablo » Sun May 19, 2019 12:18 pm
To be able to move inline style to the header, the element needs an ID. That is why it's dynamically added when you enabled "Optimize inline styles ".
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 12:22 pm
It turns out so or ID, or style in html markup?
Re: ID conflict
Post by Pablo » Sun May 19, 2019 12:25 pm
I'm sorry, can yo please more specific?
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 12:38 pm
If you enable css "Optimize inline styles" then the ID is duplicated, if you disable "Optimize inline styles", then css styles are written in the html document, which is not very good.
If you disable "Optimize inline styles"
<span style="color:#000000;font-family:'Lucida Console';font-size:13px;">Trend PD/39</span>
If you enable "Optimize inline styles" ID is duplicated as data is loaded from another page.:
<spanid="wb_uid3">Trend PD/39</span>
<span id="wb_uid3">+ 1500 </span>
Re: ID conflict
Post by Pablo » Sun May 19, 2019 12:50 pm
I do not see the duplicated IDs in your project.
Where exactly do I need to look exactly?
spoon
Re: ID conflict
Post by spoon » Sun May 19, 2019 1:07 pm
Please watch the video, it is perfectly visible in the console.
Double IDs are created when the param.html page is loaded into the index.html due to the load () method.
The text "Trend PD / 39" on the index.html page has id = "wb_uid3" and the text "+1500" on the param.html page also has id = "wb_uid3" and when the param.html page is loaded at index.html then the text style "Trend PD / 39" inherits the text style "+1500".
I do not know how else to explain))
