ID conflict
ID conflict
Hello, there was a problem with loading content from one page to another. On page 2 there is a text, id = "wb_uid" is automatically assigned to it, when I load the data from page 2 to page 1 then a conflict id = "wb_uid" occurs. What should I do?
Re: ID conflict
This ID is automatically generated when you add breakpoints, and 'keep inline styles is' disabled.
Re: ID conflict
To be able to help you I need an example project.
Related FAQ:
Also, I need to know exactly where to look to see the problem.
Related FAQ:
Re: ID conflict
What is the exact problem? Is there an error?
And what do I need to do to see the error?
Re: ID conflict
These IDs are generated because you have enabled the option
Optimize inline styles (move inline styles to the style sheet)
in Tools -> Options -> HTML
Re: ID conflict
But then the styles are written in the html markup. This is not good.
<span style = "color: # 000000; font-family: 'Lucida Console'; font-size: 13px;"> Trend PD / 39 </ span>
Re: ID conflict
To be able to move inline style to the header, the element needs an ID. That is why it's dynamically added when you enabled "Optimize inline styles ".
Re: ID conflict
It turns out so or ID, or style in html markup?
Re: ID conflict
I'm sorry, can yo please more specific?
Re: ID conflict
If you enable css "Optimize inline styles" then the ID is duplicated, if you disable "Optimize inline styles", then css styles are written in the html document, which is not very good.
If you disable "Optimize inline styles"
If you enable "Optimize inline styles" ID is duplicated as data is loaded from another page.:
<span style="color:#000000;font-family:'Lucida Console';font-size:13px;">Trend PD/39</span>
<spanid="wb_uid3">Trend PD/39</span>
<span id="wb_uid3">+ 1500 </span>
Re: ID conflict
I do not see the duplicated IDs in your project.
Where exactly do I need to look exactly?
Re: ID conflict
Please watch the video, it is perfectly visible in the console.
Double IDs are created when the param.html page is loaded into the index.html due to the load () method.
The text "Trend PD / 39" on the index.html page has id = "wb_uid3" and the text "+1500" on the param.html page also has id = "wb_uid3" and when the param.html page is loaded at index.html then the text style "Trend PD / 39" inherits the text style "+1500".
I do not know how else to explain))
