Hidden fields
spoon
Hidden fields
Post by spoon » Mon Jul 15, 2019 1:43 pm
Pablo, good afternoon, please tell me, if you use hidden fields in the form, then the data of these fields come to the mail, is it possible to exclude them for sending to the mail?
Re: Hidden fields
Post by Pablo » Mon Jul 15, 2019 1:54 pm
This is possible when using variables:
http://www.wysiwygwebbuilder.com/forum/ ... 10&t=64476
spoon
Re: Hidden fields
Post by spoon » Mon Jul 15, 2019 3:35 pm
Yes, but if you use hidden fields, then these fields fall into the letter by default. How to avoid it?
Re: Hidden fields
Post by Pablo » Mon Jul 15, 2019 4:46 pm
By default all fields are included. The server does make a difference between standard and hidden fields.
But if you use variables then you can choose which fields to include.
spoon
Re: Hidden fields
Post by spoon » Mon Jul 15, 2019 5:48 pm
The name and value of the hidden input get into the text of the letter automatically, I myself do not add them through variables.
Re: Hidden fields
Post by Pablo » Mon Jul 15, 2019 6:11 pm
Instead of using the default data. You can customize the message. If you do not include the name of the field then it will not be included in the message.
Please read:
spoon
Re: Hidden fields
Post by spoon » Tue Jul 16, 2019 2:57 am
Understood thanks.
