MOST RECENT USED (FAIL)
I HAVE VERS 15.0.3 JUL 14 2019, BUT NEVER OPEN THE MOST RECENT PROYECT AN PAGE
Re: MOST RECENT USED (FAIL)
It seems to work correct.
Can you please describe the exact steps to reproduce this problem?
I have windows 10 professional and version 15.0.4 of July 17 32 bits. Every time I start the program it does not open the last or most recent file used.Pablo wrote: Thu Jul 18, 2019 6:06 am It seems to work correct.
Maybe the file is on a different drive?
Is there an error?
Can you open the project via the menu?
Is there an error?
It´s in this C:\Users\enala\Documents\Web Builder 15 ALL\15.0.4Pablo wrote: Sat Jul 20, 2019 6:53 am Maybe the file is on a different drive?
Is there an error?
Yes I can Open from folder But Manually File + open (Folder)... etc
Sorry but I have to ask!
Have you set the option "Open the most recent used project at startup" in Options > General?
Yes. I did. But still fail.WWBman wrote: Sat Jul 20, 2019 8:56 am Sorry but I have to ask!
Is there an error?
What exactly do you mean by 'fail'?
