How to update pages that use the same master frame
giula
Post by giula »
Hi, I changed a master frame used by some tens of pages. Is it possible to update all the pages at the same time?
alan_sh
Re: How to update pages that use the same master frame
Post by alan_sh »
It should update on the screen immediately when you view the pages in WWB and should update automatically when you publish modified pages.
What is happening that makes you ask the question?
Alan
If you have changed the master frame then all pages that use that page must be republished, because the HTML of those pages has changed.
WWBman
Post by WWBman »
You can use the Pages to Publish option "Pages Using the Selected Master Pages/Master Frame" when publishing the site.
giula
Post by giula »
with your help, everything is clearer to me now. Many thanks
