Hi.
I downloaded the trial version of Quick 'n Easy Web Builder 7.x in order to understand the ability to work on Windows and Mac.
I am working on WEB BUILDER 15.1 (64 bit).
I saved my web site as Quick 'n Easy Web Builder 7.x project.
Trying to open the saved project in Quick 'n Easy Web Builder 7.x, I see the following message: Error loading: CWebProtectedPage.
I made a mistake or this because of trial version?
Thank you.
Quick 'n Easy Web Builder 7.x trial version
Re: Quick 'n Easy Web Builder 7.x trial version
I'm sorry, at the moment the 'protect page' object is not compatible with QWB7.
So, before exporting the project you wll have to remove it from the pages.
Thank you, Pablo.
Is there in QWB7 to protect a page as in WEB BUILDER, or there is some other compatible feature?
@Aris there is no need to repeatedly ask the same question you have already asked. I will lock till Pablo replies.
You can protect the pages the same way as in WWB.
However, the object cannot be exported. You will have to remove it form the WWB page and re-add it in QWB.
Unfortunately, not all features can be converted between the two formats.
Thank you, Pablo.
