Quick 'n Easy Web Builder 7.x trial version
Aris
Post by Aris » Sat Sep 21, 2019 4:46 pm
Hi.
I downloaded the trial version of Quick 'n Easy Web Builder 7.x in order to understand the ability to work on Windows and Mac.
I am working on WEB BUILDER 15.1 (64 bit).
I saved my web site as Quick 'n Easy Web Builder 7.x project.
Trying to open the saved project in Quick 'n Easy Web Builder 7.x, I see the following message: Error loading: CWebProtectedPage.
I made a mistake or this because of trial version?
Thank you.
Re: Quick 'n Easy Web Builder 7.x trial version
Post by Pablo » Sat Sep 21, 2019 5:23 pm
I'm sorry, at the moment the 'protect page' object is not compatible with QWB7.
So, before exporting the project you wll have to remove it from the pages.
Aris
Post by Aris » Sat Sep 21, 2019 7:18 pm
Thank you, Pablo.
Is there in QWB7 to protect a page as in WEB BUILDER, or there is some other compatible feature?
Post by BaconFries » Sat Sep 21, 2019 7:39 pm
@Aris there is no need to repeatedly ask the same question you have already asked. I will lock till Pablo replies.
Post by Pablo » Sat Sep 21, 2019 8:36 pm
You can protect the pages the same way as in WWB.
However, the object cannot be exported. You will have to remove it form the WWB page and re-add it in QWB.
Unfortunately, not all features can be converted between the two formats.
Aris
Post by Aris » Sat Sep 21, 2019 10:41 pm
Thank you, Pablo.
