Use of style / class in image does not disable the inline border
spoon
Post by spoon »
In 15.2.1, the "Use of style / class in image now disables inline border", but the border in ID was both present and present when setting the style / class, which means it takes precedence.
Re: Use of style / class in image does not disable the inline border
If you use a style/class, then the inline style will not be included.
This behavior has not changed recently.
spoon
Post by spoon »
If I set a style in wwb, then this style will not be used?
As before, interrupt with
!important
I'm sorry, it is not clear to me what you are trying to do.
spoon
Post by spoon »
If I set the style / class, then it sets in #wb_indexImege, not #indexImage.
Then it is not clear what means:
- Improved: Use of style/class in image now disables inline border.
It turns out that i do not change the image style since all styles / classes change the div with id = "wb_indexImage"?
The class will be applied to the <img> tag, not to the container.
This means that the border is no longer added when you specify a class.
Related topic:
https://www.wysiwygwebbuilder.com/forum ... =5&t=87041
spoon
Post by spoon »
The fact of the matter is that the class is not added to img, it is added to the div.
example
I'm sorry, but this is unrelated. You are using events, which is JavaScript.
The orginal topic was related to the 'class' property of the image object
spoon
Post by spoon »
Thanks, when to wait for the new version?
No, it works like this intentionally.
