Use of style / class in image does not disable the inline border
spoon
Post by spoon » Fri Jan 03, 2020 6:34 am
In 15.2.1, the "Use of style / class in image now disables inline border", but the border in ID was both present and present when setting the style / class, which means it takes precedence.
Re: Use of style / class in image does not disable the inline border
Post by Pablo » Fri Jan 03, 2020 8:10 am
If you use a style/class, then the inline style will not be included.
This behavior has not changed recently.
spoon
Post by spoon » Fri Jan 03, 2020 10:58 am
If I set a style in wwb, then this style will not be used?
As before, interrupt with
!important
Post by Pablo » Fri Jan 03, 2020 11:27 am
I'm sorry, it is not clear to me what you are trying to do.
spoon
Post by spoon » Fri Jan 03, 2020 12:14 pm
If I set the style / class, then it sets in #wb_indexImege, not #indexImage.
Then it is not clear what means:
- Improved: Use of style/class in image now disables inline border.
It turns out that i do not change the image style since all styles / classes change the div with id = "wb_indexImage"?
Post by Pablo » Fri Jan 03, 2020 1:35 pm
The class will be applied to the <img> tag, not to the container.
This means that the border is no longer added when you specify a class.
Related topic:
https://www.wysiwygwebbuilder.com/forum ... =5&t=87041
spoon
Post by spoon » Fri Jan 03, 2020 1:40 pm
The fact of the matter is that the class is not added to img, it is added to the div.
example
Post by Pablo » Fri Jan 03, 2020 2:22 pm
I'm sorry, but this is unrelated. You are using events, which is JavaScript.
The orginal topic was related to the 'class' property of the image object
spoon
Post by spoon » Fri Jan 03, 2020 4:05 pm
Thanks, when to wait for the new version?
Post by Pablo » Fri Jan 03, 2020 4:17 pm
No, it works like this intentionally.
