Hi pablo,
I have in my project (one page project) a photo-collage object with 19 images nested in layout grid.
The problem is this: when i try to scroll the page it fail rendering when it reaches the the photo-collage object.
The render of page doesn't work anymore.
In order to continue work Ineed :
1. Disable photo-collage object with object manager.
2. Save the project
3. Reopen it
If you need entire project let mi know where I can send It.
Thank You
photo collage problem rendering page
- crispy68
Re: photo collage problem rendering page
Do all of the images have web-safe names? No spaces, strange characters, etc.?
Yes only under_score.
But the problem is in the rendering of project.
Everything works fine when I upload the page.
Do you have the latest version of the software?
Do you have Windows 10?
Do you have a demo project so we can see what you have done?
Yes I have latest version and windows10.
Here you can download entire project (Now with PhotoCollage1 object active)
terrazzeastroniaeventi.com/AstroniaEventi.rar
I would be grateful if you could take a look at it
- crispy68
I have no problem scrolling to the bottom of your project. However......it was slow.
The first thing that sticks out to me is that your images are WAY too large! A majority of them are 3000-5000px wide. This will cause the program to load slow due to all these large images. You need to reduce/optimize the images down to the largest size you need them THEN import them into the project.
What this means is this, if the image will only be as large as say 600px then you need to reduce the image down to this size first.
For example, in your project in the first section under "Astronia Evente" you have 2 images on the right. The first image is 4928 x 3264 but is only about 515px wide in the project and when previewed. Reduce the size down to about 600px wide and then re-insert it. Do this for every image and I think you will fix your problem.
Thank you for taking part of your time for me.
I'll try'.
I planned to reduce the size of the images generally I do it in the end by resizing all the images in the project folder
Thank you very much
I'll try'.
Thank you very much
For your proper knowledge the problem has been solved by resizing the images,
