*** SOLVED *** the latest version of WYSIWYG Web Builder 15.4.3
luishmpaulo
Post by luishmpaulo » Mon Jun 22, 2020 2:29 pm
Hi!
I downloaded the latest version (64-bit) as always, but I can't install it: I click on "setup.exe" and nothing happens ...
WWBman
Re: the latest version of WYSIWYG Web Builder 15.4.3
Post by WWBman » Mon Jun 22, 2020 2:52 pm
Try rebooting your PC.
Bluesman
Post by Bluesman » Mon Jun 22, 2020 2:53 pm
Hi!
Nobody else seams to have this problem, including me. Think you must give Pablo some more info? Have you done any changes to your OS since the last update? Have you installed any antivirus or other security Softwares...
Have you restarted your PC?
"Make My Day"
See my Website
Post by Pablo » Mon Jun 22, 2020 2:55 pm
Usually (this is a related to a firewall or virus scanner blocking the software.
To solve it, add the setup to the exception list
luishmpaulo
Post by luishmpaulo » Mon Jun 22, 2020 3:03 pm
TKS! I'll try.
luishmpaulo
Post by luishmpaulo » Mon Jun 22, 2020 3:44 pm
No changes in my PC since the update before this one.
I restarted minutes ago, but "setup.exe" doesn't respond.
I disabled Kaspersky (which never blocked the installation), but it still doesn't work.
Well, if I find what is wrong I'll come back to tell.
alan_sh
Post by alan_sh » Mon Jun 22, 2020 4:03 pm
Are you running it from within the Zip file or extracting it first?
Try starting task manager first and see if it's getting started and then exiting or not even getting that far.
Alan
jerryco
Post by jerryco » Mon Jun 22, 2020 4:04 pm
Are you logged in as Administrator?
luishmpaulo
Post by luishmpaulo » Mon Jun 22, 2020 4:07 pm
Extracting first.
I tried the task manager but it didn't get there. I also tried to run as an administrator, with no effect.
jerryco
Post by jerryco » Mon Jun 22, 2020 6:24 pm
Can you re-download the setup file and run that again? Maybe the file got corrupted on the way to your pc?
alan_sh
Post by alan_sh » Mon Jun 22, 2020 10:58 pm
Extracting first.
Where are you extracting it to?
Alan
luishmpaulo
Post by luishmpaulo » Tue Jun 23, 2020 1:09 pm
To My Computer/Downloads files... As always.
jerryco
Post by jerryco » Tue Jun 23, 2020 1:30 pm
luishmpaulo
Post by luishmpaulo » Fri Jun 26, 2020 5:49 pm
I tried, no effect.
And a curiosity: this is the only "setup.exe" that doesn't run. I tested run others, from others programs, and they started installing . I really don't know what else to do, I think I'll wait for the next update...
Post by Pablo » Fri Jun 26, 2020 6:14 pm
There is really nothing wrong with the file. it's the same as every other update.
I think your firewall or virusscanner is blocking the application. To solve this, add the setup to the exception list or look for a more reliable virusscanner /firewall.
