Card container contents refusing to center on page.
I'm experimenting with cards within WB 15.44 at the moment. However, when pacing a group of say four cards in a row within a card container, the container and the cards fail to center within the web page even when I set the page properties to center horizontally. Any ideas? Or is a card container unnecessary?
Re: Card container contents refusing to center on page.
It seems to work correct for me.
What are your exact settings?
Do you have a demo project?
Related FAQ:
Note that 'center in browser' in the page properties should be off for flexible layouts. This is only for absolute/fixed layouts.
Related FAQ:
Okay, here is a copy of the test file for you to have a look at.
http://poetrycards.me.uk/cards test.wbs
In the page properties, set page alignment to 'do not center'
If you want to center the cards, then enter a "max-width" otherwise the container will be 100%
Hmmm...still not working. Is there an issue with card containers being centered?
Everything works correct.
What did you expect to happen?
Still not centering on page after following your instructions!
I'm sorry, in that case I do not think I understand what you are trying to do.
Can you please update your demo project and remove all other non-relevant content to prevent confusion.
Which part of the layout do you want to center?
What should it look like?
Why are you using a card container in a fixed layout?
