Card container contents refusing to center on page.
iMatt
Post by iMatt » Tue Jul 14, 2020 9:59 am
I'm experimenting with cards within WB 15.44 at the moment. However, when pacing a group of say four cards in a row within a card container, the container and the cards fail to center within the web page even when I set the page properties to center horizontally. Any ideas? Or is a card container unnecessary?
Re: Card container contents refusing to center on page.
Post by Pablo » Tue Jul 14, 2020 10:04 am
It seems to work correct for me.
What are your exact settings?
Do you have a demo project?
Related FAQ:
Note that 'center in browser' in the page properties should be off for flexible layouts. This is only for absolute/fixed layouts.
iMatt
Post by iMatt » Tue Jul 14, 2020 10:57 am
Okay, here is a copy of the test file for you to have a look at.
http://poetrycards.me.uk/cards test.wbs
Post by Pablo » Tue Jul 14, 2020 11:08 am
In the page properties, set page alignment to 'do not center'
If you want to center the cards, then enter a "max-width" otherwise the container will be 100%
iMatt
Post by iMatt » Tue Jul 14, 2020 12:02 pm
Hmmm...still not working. Is there an issue with card containers being centered?
Post by Pablo » Tue Jul 14, 2020 12:27 pm
Everything works correct.
What did you expect to happen?
iMatt
Post by iMatt » Tue Jul 14, 2020 12:33 pm
Still not centering on page after following your instructions!
Post by Pablo » Tue Jul 14, 2020 1:02 pm
I'm sorry, in that case I do not think I understand what you are trying to do.
Can you please update your demo project and remove all other non-relevant content to prevent confusion.
Which part of the layout do you want to center?
What should it look like?
Why are you using a card container in a fixed layout?
