Free template: Minimalist gradient
Please post free templates here
filmphotog
Post by filmphotog » Fri Sep 25, 2015 11:40 am
Free WYSIWYG Web Builder template: Minimalist gradient
I made a template in similar design as my other themes. Perhaps someone is interested in using this template as a start and continue to modify the pages.
Terms of use: Free
Extensions needed: None
No licensed images were used.
Responsive Web Design
- 6 breakpoints, 320 480 640 768 1024 1280 (the two largest are reduced to 994 and 1250 for scrollbars in browswers)
- Master Frame is used for all pages (two master frames because of different links in the menu)
- Panel Menu on the left side, opens with the hamburger icon
- Activate social media links in the Image Map properties
- Contact form with success/error pages
- Startpage and 6 additional pages
For the many breakpoints, it's for the best viewing experience on mobile devices.
Examples:
320x480 for iPhone 5
320x640 for iPhone 6
768x1024 for iPad
1280 for laptop/desktop
Fully functional demo
Template for download
Hope this template is useful, thanks.
______________________
Same as above but in blue color scheme: Template for download
eddie the taxi
Re: Free template: Minimalist gradient
Post by eddie the taxi » Fri Feb 26, 2016 6:23 pm
You must have spent hours getting this right, I cannot use the template because I have use bits and pieces from other templates but the break points will come handy thanks for sharing
what would you rather be or a wasp
filmphotog
Post by filmphotog » Fri Feb 26, 2016 6:33 pm
eddie the taxi wrote:You must have spent hours getting this right, I cannot use the template because I have use bits and pieces from other templates but the break points will come handy thanks for sharing
Thank you very much for the comment :D It gets easier after a few templates. Hope you can use some of it.
Users browsing this forum: No registered users and 5 guests
