Free template: Minimalist black
Please post free templates here
filmphotog
Post by filmphotog » Fri Oct 23, 2015 5:23 am
Free WYSIWYG Web Builder template: Minimalist black
This template is a one-page layout with navigation between bookmarks. Perhaps someone is interested in using this template as a start and continue to modify the page.
Terms of use: Free
Extensions needed: None
No licensed images were used, the picture was taken by me and is free to use.
Responsive Web Design
- 7 breakpoints, 320 360 400 540 620 700 900
- Panel Menu
- One-page layout
Fully functional demo
Template for download
Hope this template is useful, thanks.
wacki56
Re: Free template: Minimalist black
Post by wacki56 » Fri Oct 23, 2015 3:11 pm
As always, Thank you for sharing your work with forum members, and at no cost.
Bill
filmphotog
Post by filmphotog » Fri Oct 23, 2015 3:31 pm
wacki56 wrote:As always, Thank you for sharing your work with forum members, and at no cost.
Bill
Thank you very much for the comment! :D - The inspiration for this template was this website :wink:
electrochrisso
Post by electrochrisso » Sat Oct 24, 2015 2:29 am
filmphotog wrote:Thank you very much for the comment! - The inspiration for this template was this website
Thanks here too filmphotog, although I found the site you got your inspirition from is extremely bloated for which the site developers should have a look at that, your demo is fine and loads fast, so the use of your template and thoughtful use of images etc should produce very good results. :)
filmphotog
Post by filmphotog » Sat Oct 24, 2015 6:12 am
Thank you for the comment! :D I prefer lightweight too, especially for responsive web design when the device viewed on could be small and the connection slower.
liquid
Post by liquid » Mon Oct 26, 2015 11:08 am
hello and thanks for sharing your works. I would like a question:
the slideshow is a component that compatible with RWD pages like your template. well, why if I insert a slideshow in one of page when I launch the preview, I don't see it?
thanks
filmphotog
Post by filmphotog » Mon Oct 26, 2015 12:01 pm
liquid wrote:hello and thanks for sharing your works. I would like a question:
thanks
Hi and thanks,
The slideshow has to be manually resized for each breakpoint.
I usually set the initial size to 320px wide and place it at the left border. This way it will be visible in the 320 breakpoint. Go to the 320 breakpoint and see if it's ok. In the next larger breakpoint resize the slideshow to fit, and the same in all larger breakpoints.
Note the layer needs to be unlocked when adding new objects, also check the Object Manager that the slideshow is "child" of the layer.
Hope it works.
mayur007
Post by mayur007 » Mon Oct 26, 2015 1:53 pm
once again thanx for the template :D
making everyone's work easy and fast :wink: keep it up :D
filmphotog
Post by filmphotog » Mon Oct 26, 2015 5:19 pm
mayur007 wrote:once again thanx for the template :D
Thank you very much for the comments! :D
I also used this template for an update on my photo page leicafilmphotography.se It's slower than I would like tough, because of all images and photo galleries.
liquid
Post by liquid » Mon Oct 26, 2015 6:12 pm
thanks
Hi and thanks,
Hope it works.
Hi, thanks for the reply. I'll try tomorrow and I tell you if it's ok.
bye
