Atlantis Radio Free WYSIWYG Web Builder Template
Please post free templates here
dapson
Post by dapson » Sat Nov 05, 2016 10:02 pm
Atlantis Radio is a free WYSIWYG Web Builder Template with awesome features. This single page template makes it possible for you to include details about your organization in style.
Features:
- Javascript Events
- Tunein Live radio widget
- Fully Responsive
- Responsive Text
Version Used
WYSIWYG Web Builder version 11.2.4 - See more at: https://dapsonishmeal.com/free-template ... EH8gy.dpuf
****Note: images in the template are for demonstration purpose only, therefore we require you change them in your project ****
Re: Atlantis Radio Free WYSIWYG Web Builder Template
Post by BaconFries » Sat Nov 05, 2016 11:15 pm
As always it needs to be asked. Are the images used in the template have any copyright attached? do you as the distributor of the template have the right to redistribute the images? Are the images licenced for distribution? If the answer is no to any of these then due to the Rules regarding templates you will have to remove or state that the images cannot be used and once downloaded be removed and replaced with the users own images.
When using a external widget as such in a template you are obliged to include a copy of the following for users information.
End User License Agreement And Terms Of Service
dapson
Post by dapson » Sat Nov 05, 2016 11:19 pm
Hello BaconFries, Thanks for the info, there is a file in the template which has a clear statement stating "images in the template are for demonstration purpose only, therefore we require you change them in your project"
Post by BaconFries » Sat Nov 05, 2016 11:31 pm
OK thanks As a suggestion maybe include a copy of the widgets EULA for the user to read regards the use.
dapson
Post by dapson » Sat Nov 05, 2016 11:33 pm
Sure BaconFries, i have included that as well. Thanks alot. I really appreciate
