Editor for CMS
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
mckrahman
Editor for CMS
Post by mckrahman » Mon Apr 17, 2017 11:03 am
Hi everybody
Can anyone suggest an editor good one for cms ?
Re: Editor for CMS
Post by Pablo » Mon Apr 17, 2017 11:07 am
I think you will need to try them all to find out which one works best for you.
mckrahman
Re: Editor for CMS
Post by mckrahman » Mon Apr 17, 2017 11:18 am
Thank you Pablo
can i use multiple CMS view in a form ?
Thank You
Re: Editor for CMS
Post by Pablo » Mon Apr 17, 2017 12:38 pm
You can only use one 'dynamic' view per page.
But you can use multiple 'static' views.
mckrahman
Re: Editor for CMS
Post by mckrahman » Mon Apr 17, 2017 2:05 pm
From where shall I get static view from tool box.
Thank you
Re: Editor for CMS
Post by Pablo » Mon Apr 17, 2017 2:24 pm
It's the same object. In the properties you can set it to 'fixed context'. See the help for more details about this option.
mckrahman
Re: Editor for CMS
Post by mckrahman » Mon Apr 17, 2017 4:35 pm
Thank you so much pablo.
