CMS Web
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
pajadt
CMS Web
Post by pajadt » Fri Aug 25, 2017 1:04 pm
Hi
I have one question is now cms resposive?
Thank You
Re: CMS Web
Post by BaconFries » Fri Aug 25, 2017 1:24 pm
The CMS view itself is responsive.
pajadt
Re: CMS Web
Post by pajadt » Fri Aug 25, 2017 1:29 pm
Thank You Bacon,
I ask for this, is resposive if yes where i can find example.
Thank You
Re: CMS Web
Post by Pablo » Fri Aug 25, 2017 1:44 pm
The CMS View is responsive, which means that it can be used in breakpoints.
The example does not implement breakpoints, it focuses on the main CMS functionality.
pajadt
Re: CMS Web
Post by pajadt » Fri Aug 25, 2017 1:56 pm
Thank You Pablo,
i see that, but i try to do with layout grid full CMS i can't, so that is why i ask for example responsive.
Re: CMS Web
Post by Pablo » Fri Aug 25, 2017 2:06 pm
What is the exact problem?
pajadt
Re: CMS Web
Post by pajadt » Fri Aug 25, 2017 2:11 pm
not problem any, i ask only how to create full cms wtih Layot grid to be resposive and if have example it be great
Thank You
Re: CMS Web
Post by Pablo » Fri Aug 25, 2017 2:32 pm
Using the CMS tools in a responsive layout does not work any different than in a standard layout.
You can use CMS view in a layout view and it will automatically resize the content.
pajadt
Re: CMS Web
Post by pajadt » Fri Aug 25, 2017 2:47 pm
ok one more can i used materframe or must be masterpage and we finished
Thank You
Re: CMS Web
Post by Pablo » Fri Aug 25, 2017 5:07 pm
For what exactly?
