CMS View
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
Hurtado
CMS View
Post by Hurtado » Wed Jul 11, 2018 8:15 am
CMS View is not responsive?
Re: CMS View
Post by Pablo » Wed Jul 11, 2018 8:55 am
The CMS view is responsive. It can have a different size in breakpoints.
Hurtado
Re: CMS View
Post by Hurtado » Wed Jul 11, 2018 10:00 am
Then, why not work with flex grid?. I don´t understand
Hurtado
Re: CMS View
Post by Hurtado » Wed Jul 11, 2018 10:55 am
In layout grid work fine
Re: CMS View
Post by Pablo » Wed Jul 11, 2018 11:59 am
You have already asked this yesterday...
CMS view does not support flex box.
maxime
Re: CMS View
Post by maxime » Thu Jul 12, 2018 6:45 pm
to make it work in a flexgrid try this:
put the cms view object on your page, configure it then look a the code create. copy the code and put it in the page html at start page. then remove the the cms object. you should also remove the following code
<?php
   echo $cms_content;
from the code you just have copied because this code will be put at this second step
then after
in a html object put this : choose also the NO DIV option
 <?php
   echo $cms_content;
put the html object in the flex grid section you want.
Hurtado
Re: CMS View
Post by Hurtado » Mon Jul 16, 2018 12:30 pm
thanks
