[rz] "Slidable" fullsize ad on top *** UPD 2018-Jun-06 ***
Re: "Slidable" fullsize ad on top *** UPDATED Jun-04-2013 *
Post by [RZ] » Thu Feb 13, 2014 8:10 pm
if you want to use a modal window, like the jquery dialog, you should consider the [rz] Alert extension (http://wysiwygwebbuilder.com/forum/view ... 42&t=59998) -- it will always be shown in the exact same place, even when the [rz] Advertisement is opened
Post by [RZ] » Thu Feb 13, 2014 8:16 pm
JohnB wrote:Can i disable the scroll function when the page is shown? Because when the page is shown the Auto Open is on 1.
But i don't want to lose the nice scroll efects when show or hiding the header. When the user goes on the pages the
scroll moves the page down and thats not nice.
no, you cannot do this, there is a technical reason
you are working in a fixed layout, and start a page with the layer opened, will flicker the page, this undesirable visual effect will be far worst than the issue you are describing now
JohnB
Post by JohnB » Fri Feb 14, 2014 8:20 am
Thank you for your quick answers.
I give up, i will have to many problems to replace the jQuery Windows like the search object and
Photo Gallery objects.
It would be nice to have a extension like this, to show and hide the top header/ menu that stays on top
and the content are scroll bellow. I have seen this function in many sides.
Is there anotherway to do that, to hide / show the header ? I have done that with a button, but the content are not scroll down
or up when the header/ hides or shows.
Thank you again for you help and support
John
Post by [RZ] » Fri Feb 14, 2014 8:30 am
for advanced layers management, you can try: http://wysiwygwebbuilder.com/forum/view ... 53&t=56261
however, the page content won't scroll -- i already tried this, but found some compatibility issues
(of course you can do it, but adding custom code, [rz] Layers II allows this)
i will retry a new concept, but not now, unfortunately, i don't have a free timeframe for this yet
JohnB
Post by JohnB » Fri Feb 14, 2014 8:35 am
Thank you!
John
Re: "Slidable" fullsize ad on top *** UPD 2014-Oct-14 ***
Post by [RZ] » Tue Oct 14, 2014 4:43 pm
UPGRADE AVAILABLE
* New in version 1.2.0:
- Added support for RWD.
- Added optional push images.
- Added lean out property; the size in pixels that the advertisement object leans out when it is (partially) closed.
- Now all the images are optional (at least one must be entered to open the layer; in that case, the same image will be used to open and close it).
- Improved objects order for a better keyboard-based navigation.
- Improved backward compatibility for older browsers.
- Fixed a bug in 3D push effect.
- Improved during-sliding events call.
Functions added:
You programmatically can open, close and toggle the layer on top.
MyExtension.open(); to open the layer on top.
MyExtension.close(); to close the layer on top.
MyExtension.close(); to open the layer on top if it is closed, or close it if it is opened.
mayur007
Post by mayur007 » Thu Oct 16, 2014 5:50 pm
hi will this work same as panel
+ sign can be edited with any name and dragged anywhere ??
Post by [RZ] » Thu Oct 16, 2014 6:00 pm
a working demo is here: http://www.magnawebstudio.com
click on the orange angled image (top right)
you can use the image you want and customize the position
also you can programmatically open and close the layer
Re: [rz] "Slidable" fullsize ad on top *** UPD 2015-Apr-07
Post by [RZ] » Tue Apr 07, 2015 9:24 am
* New in version 1.2.0.1:
- Improved support for iOS based devices.
- Improved RWD support.
- Improved button behavior.
- The "open" image is mandatory, the other ones are optional.
Re: [rz] "Slidable" fullsize ad on top *** UPD 2015-Jul-02
Post by [RZ] » Thu Jul 02, 2015 9:42 am
* New in version 1.2.0.2:
- Improved keyboard navigability behavior when the advertisement object leans out.
- Added optional image-size definition to allow a better implementation in Retina-based devices.
Post by zinc » Thu Jul 02, 2015 11:50 am
A very welcome feature! :)
Re: [rz] "Slidable" fullsize ad on top *** UPD 2016-Oct-05
Post by [RZ] » Wed Oct 05, 2016 11:41 am
* New in version 1.3
- The virtual 'onslide' event is more sensitive to programatically allow better objects relocation or changes on advanced responsive/fluid schemes.
- More button alignments.
- Improved button image customization.
- Improved core and moved to external library.
Re: [rz] "Slidable" fullsize ad on top *** UPD 2018-Jun-06 ***
Post by [RZ] » Tue Jun 05, 2018 11:34 pm
* New in version 1.3.1
- Added support to work also in floating layers schemes.
- Minor tweaks in the code.
