[rz] Parallax Objects *** UPD 2014-Nov-13 ***
FX3D
Re: [rz] Parallax Objects *** UPD 2014-Nov-13 ***
Post by FX3D » Sat Nov 15, 2014 7:21 pm
Asir Todah, Balnes [Rz]
Really appreciate all of your hard work :P
FX
sailorspy
Post by sailorspy » Tue Dec 02, 2014 7:13 am
Hi there,
I just bought this extension as I wanted an effect like your Demo (section 3) with the scrolling backgrounds. The effect works only at certain page sizes. If the browser size is changed the effect goes wrong. However this does not happen on your demo. Any idea what I am doing wrong ?
A tutorial on how you did the sliding background effect would be useful :D
Post by [RZ] » Tue Dec 02, 2014 9:24 am
i do not see any issue in your sample, please read carefully again the instructions :) perhaps you need to manually adjust the page length (as in the demo)
the extension comes with a sample
sailorspy
Post by sailorspy » Tue Dec 02, 2014 9:31 am
Where is the sample ? It wasn't in the file sent by email.
Post by [RZ] » Tue Dec 02, 2014 9:46 am
seems the file is missing, sorry
it has accidentally been deleted
i will search for it and let you know
sailorspy
Post by sailorspy » Tue Dec 02, 2014 9:59 am
Thank you.
Post by [RZ] » Thu Dec 11, 2014 5:56 pm
pls get in contact here: www.magnawebstudio.com/shop
so you can receive the test project file for the extension
Post by [RZ] » Mon Jun 15, 2015 6:12 am
if you mailed, you do not need to post here again :)
w/regards
luishmpaulo
Post by luishmpaulo » Fri Sep 18, 2015 4:56 pm
This demo - http://www.magnawebstudio.com/demo/para ... age_1.html - is a fixed page for me (using Chrome 45.0.2454.93 m version...
Post by [RZ] » Sat Sep 19, 2015 4:59 pm
the demo is not a fixed background at all
just look again at the elements with the transparencies
drag the scrollbar track to see the effect, perhaps the scrollbar arrows in chrome are not so smooth
karmacomposer
Post by karmacomposer » Thu Dec 03, 2015 3:02 pm
I know this thread is a bit old, but I really need parallax capability and bootstrap is a bit of a pain, so I'd rather use my tried and true WYSIWYG Builder 10.
Does this webpage: http://www.magnawebstudio.com/demo/para ... age_3.html
Come with your Parallax Objects control for WYSIWYG Website Builder 10?
I am really in need of this effect and if I can create that kind of parallax website (responsive as well) with WYSIWYG Builder 10, then I need to buy this ASAP.
Which pack does it come in (Pro, Gold. Diamond)? I'd rather buy a pack and get a bunch of extensions then just one.
I assume you support this extension if I have questions?
Mike
Post by [RZ] » Thu Dec 03, 2015 3:07 pm
the extension is supported
rwd is possible
includes a sample
does not include the demo
is not included in the packs you mention, however is included in the subscriber plan or as a single
karmacomposer
Post by karmacomposer » Thu Dec 03, 2015 4:20 pm
How hard would it be to re-create that basketball demo site?
I'll buy that extension today some time.
Mike
Post by [RZ] » Thu Dec 03, 2015 4:29 pm
if you already have the graphical elements, the idea about what you want to accomplish and some basic wb skills, just some minutes
for very complex designs, perhaps some maths may help, and some minor adjustments until you get the final desired result
