[rz] Background Images II *** UPD 2018-Dec-31 ***
Re: [rz] Background Images II *** UPD 2018-Jan-17 ***
Post by [RZ] » Wed Jan 17, 2018 4:24 pm
* New in version 2.0.1
- Navigation dots can optionally have customizable ordinal numbers for the images, uppercased/lowercased letters or roman numbers; these dots can be colored, image-based or thumbnails based.
- Improved color setup for the navigation dots.
Post by zinc » Thu Jan 18, 2018 7:30 am
A Total GEM!!!!!! Thank you RZ!
Post by [RZ] » Thu Jan 18, 2018 8:32 am
thank you for your support :)
Re: [rz] Background Images II *** UPD 2018-May-11 ***
Post by [RZ] » Fri May 11, 2018 11:58 am
* New in version 2.0.2
- Selectable specific scripts for new wb14 Carousel variants.
- Minor script improvements.
Post by zinc » Fri May 11, 2018 12:02 pm
Needless to say: THANK YOU!!!
Post by [RZ] » Fri May 11, 2018 12:16 pm
thank <you> for supporting my hard work behind the scenes!
Re: [rz] Background Images II *** UPD 2018-Jun-02 ***
Post by [RZ] » Sat Jun 02, 2018 8:45 pm
* New in version 2.1
- Improved slide effect; now it behaves normal or cycled (resulting in eight modes).
- Image-specific background color (meaningful with cycle-based effects and with slight opacities for background tint simulation).
- Space around the instance in percentages and/or pixels; this allows to setup the background areas to not be covered.
- Fixed a minor blur transition issue on Edge.
- Fixed a minor z-order issue in layers with other relative elements on some browsers.
- Minor code optimizations.
- New extension: [rz] Background Images (synchro); it allows to start all the [rz] Background Images instances in the same page at the same time once all of them are ready and their images have been loaded.
Post by zinc » Sun Jun 03, 2018 5:14 pm
Thank you so much for the implementing my requests. Most grateful!!!! :D
Post by [RZ] » Mon Jun 04, 2018 10:27 am
onlye
Post by onlye » Thu Jul 12, 2018 4:47 am
Is the license for a website developer a per site license? ie i develop for customers, is a license required for each customer website I use background images?
thanks
Post by [RZ] » Thu Jul 12, 2018 5:23 am
please contact privately for details
(following the links below this post)
Re: [rz] Background Images II *** UPD 2018-Dec-31 ***
Post by [RZ] » Mon Dec 31, 2018 8:18 am
* New in version 2.1.0.1
- Horizonal and/or vertical offsets for the dots specific to the current image.
Post by zinc » Wed Jan 02, 2019 8:59 am
Lovely feature!!!! :D
Post by [RZ] » Wed Jan 02, 2019 9:35 am
thank you for your kind feedback
