[rz] Styled gMaps *** UPD 2018-Feb-01 ***
maxam
Re: [rz] Styled gMaps *** UPD 2016-Sep-18 ***
Post by maxam » Wed Nov 30, 2016 5:14 pm
Thank you, RZ! Got the stuff! just a quick question, where exactly in the options should I look for changing map color parameters?
Post by [RZ] » Wed Nov 30, 2016 5:29 pm
mainly, in properties / map / elements
please read carefully and in full the properties descriptions
if you have further questions please contact privately
hope this helps
maxam
Post by maxam » Wed Nov 30, 2016 6:04 pm
I can't see personal message option here...
Post by [RZ] » Wed Nov 30, 2016 6:05 pm
pls use the contact form in the shop site
Re: [rz] Styled gMaps *** UPD 2017-Feb-01 ***
Post by [RZ] » Wed Feb 01, 2017 12:39 pm
* New in version 1.0.1
- Addresses: Resolved a bad parameter conformation in case of using the default address marker.
- Infowindow: Improved optional image styling.
- Infowindow: Improved optional 'read more' button styling.
- Infowindow: Improved optional framework styling.
Re: [rz] Styled gMaps *** UPD 2017-Apr-13 ***
Post by [RZ] » Thu Apr 13, 2017 12:19 pm
* New in version 1.0.1.1
- Handling gestures modes; improves navigability on mobiles (prevents collisions when dragging the page and/or the map).
- Clickable icons option; specifies if map icons are clickable or not (usually a POI is a clickable icon).
Post by zinc » Fri Apr 14, 2017 3:49 pm
Thanks again for getting it done in time!!!
Post by [RZ] » Sat Apr 15, 2017 5:16 pm
thank you for your feedback!
Re: [rz] Styled gMaps *** UPD 2017-Jul-20 ***
Post by [RZ] » Thu Jul 20, 2017 9:27 pm
* New in version 1.0.2
- Predefined styles; 15 built-in elegant styles included to make the instance even easier and quicker to setup.
- Minor markup tweaks.
Re: [rz] Styled gMaps *** UPD 2018-Feb-01 ***
Post by [RZ] » Wed Jan 31, 2018 11:23 pm
* New in version 1.0.2.1
- Resolved a resize/relocation sporadic issue on older browsers and/or slower platforms due to changes in the Google's API.
- New five built-in styles.
- Minor code tweaks.
