[rz] Characters Assistant *** UPD 2019-Apr-20 ***
Post by [RZ] » Thu Jul 06, 2017 4:27 pm
[rz] Characters Assistant v1.1
This solution helps visitors to fill forms with special/international characters.
Just press and hold a standard key, if that key has alternative values, a bottom panel is opened with all the available variants. Character tables are user defined and customized according to the specific regional requirements.
A file with characters table is included and the extension itself has a basic internationalization sample for a quicker and easier startup.
Some features:
- Handled via keyboard and mouse.
- Colors and transparencies for the panel background.
- Customizable buttons appearance with colors for their different statuses.
- Customizable keyboard "sensitiveness".
- Smooth color transitions (some browsers may not support this feature).
- Based on a fluid scheme for its funtionality.
- Maximum backward and cross-browser compatibility.
- Lightweight, no dependencies, no jQuery.
...and more
HTML 4.01 Transitional
W3C compliant
DEMO
* New in version 1.1
- New 'context' for the panel (useful for inlineframes).
- New 'handler' for all entry elements or for specific ones.
- Improved navigability.
- Improved cross-browser and backward compatibility.
How to use?
1. Design your form as you usually do.
2. Drag and drop an instance to the workplace.
3. Enter the characters that will have a set of characters associated.
4. Optionally, setup the style or leave it as by default.
5. Preview or publish.
Enjoy!
Re: [rz] Characters Assistant
Post by zinc » Thu Jul 06, 2017 4:51 pm
A very elegant solution/approach!!! Nice one RZ
Post by [RZ] » Thu Jul 06, 2017 5:09 pm
thank you! :)
Re: [rz] Characters Assistant *** UPD 2019-Apr-20 ***
Post by [RZ] » Sat Apr 20, 2019 6:55 pm
