[rz] Modern Hyperlink *** UPD 2018-Feb-23 ***
Post by [RZ] » Sun Dec 31, 2017 10:40 pm
[rz] Modern Hyperlink v1.0.1
The most simple and lightweight solution to transform classic links to modern and trendy ones.
- Background position, sizes, colors and opacity level control for different statuses.
- Optional foreground colors for different statuses.
- Transition customization for smoother and elegant effects.
- Padding control for even better visual results.
- Focus behavior control.
- Multi-instance to control several objects with different parameters.
- Multi-target to control several objects that share the same parameters.
- Maximum cross-browser, cross-platform and backward compatibility.
- Lightweight, no jQuery required.
...and more!
HTML 4.01 Transitional
W3C compliant
DEMO
* New in version 1.0.1
- Improved cross-browser link alignments on text blocks.
- Added radius for different statuses with optional timed transition for smoother effects.
How to use?
1. Design your page with text objects and links within them as you usually do.
2. Drag and drop the extension and enter the objects id that have links and you want to convert.
3. Optionally, setup the styles according to your scheme/design.
4. Preview or publish.
Enjoy!
Re: [rz] Modern Hyperlink *** UPD 2018-Feb-23 ***
Post by [RZ] » Fri Feb 23, 2018 1:54 pm
