settings to avoid post spam tray
saulmeza
Post by saulmeza » Fri Oct 21, 2016 7:35 am
I have set my form with my hotmail and send me messages received in the tray spam ... what should I do in the settings so that it does not acurra? (No matter that the autoresponder have that problem since I pointed it out to the subscriber on the page thanks)
In Mail engine is the solution? by now in the "mail" option
Re: settings to avoid post spam tray
Post by [RZ] » Fri Oct 21, 2016 7:57 am
use the secure senders list (hotmail settings)
contact forms are not "real" mails sent from a different email address, hence, hotmail treats them as spam/suspicious by default
Post by Pablo » Fri Oct 21, 2016 9:09 am
There are no settings in the form that can prevent the email to go to spam. If that was possible the spammers would use the same settings...
saulmeza
Post by saulmeza » Fri Oct 21, 2016 5:24 pm
:cry: thanks
bburgess
Post by bburgess » Fri Oct 21, 2016 10:19 pm
saulmeza wrote::cry: thanks
Do not despair mate! I had the same issue, an easy fix and a more secure email to use in your form if your not using a form processor is:
33mail.com where you can create for free a disposable mail that Hotmail.com will not block etc.
https://www.33mail.com/ create an account, set your desired email name such as "saulmeza" and then use a disposable email in your form or processer such as "contact@saulmeza.33mail.com"
33mail takes care of it all, I have had no issues in the last 12 months of use, since I joined. Hotmail accepts the mail from 33mail.com with no issues.
Hope that helps
Cheers
BB
saulmeza
Post by saulmeza » Sun Nov 20, 2016 11:50 pm
We will try it, thank you very much :D
bburgess
Post by bburgess » Sun Dec 11, 2016 11:03 pm
saulmeza wrote:We will try it, thank you very much :D
No problems mate, hope it works out ok :)
Cheers
BB
