cssMenu ignores padding of layoutGrid
Ainu
Post by Ainu » Wed Jan 11, 2017 8:45 am
Why does the cssMenu ignore the padding of the layoutGrid on small screensizes?
The above menu is a simple text object with padding and background-color. It scales fine.
The menu below is the cssMenu, with stretch mode. It's all scaling fine untill i get to about 320px. As you can see there is enough space left on the left-right side to scale a little further, but it doesn't.
Re: cssMenu ignores padding of layoutGrid
Post by Pablo » Wed Jan 11, 2017 9:52 am
Please share your project. Before sharing it please remove all non-relevant content form the project.
Ainu
Post by Ainu » Wed Jan 11, 2017 11:43 am
I solved it while making a example project for you. The problem was in cssMenu > Style > Text > Padding left/right.
The padding was set at 20. This was forcing the menu to dissapear out of the window. When i set the padding for text to 0 the cssMenu scales very well, even for very small window sizes.
