Flex Grid/break point problem
jbra
Post by jbra » Wed May 16, 2018 6:02 pm
I create a page including a flex grid and set properties of flex grid, include objects in cells, ... Page is OK.
I then add a breakpoint, the flex grid is there but has nothing in common with original page flex grid (it is the default one when creating a flex grid).
What have I done bad ?
Thanks.
Re: Flex Grid/break point problem
Post by Pablo » Wed May 16, 2018 6:05 pm
If you add a new breakpoint then the layout will be copied from the default view.
jbra
Post by jbra » Wed May 16, 2018 8:04 pm
Thanks, that is right, if breakpoint is created after flex grid, its content is correct.
This is quite uneasy : adding a flexgrid with existing breakpoints means editing 'default' layouts in each breakpoint (ie creating from scratch). You cannot even copy/paste flex grid, it turns to default layout.
Is there a smarter way to do things ?
Post by Pablo » Wed May 16, 2018 8:33 pm
I am not sure if this will work, but you can try:
- go to the default view
- select the object
- right click the n Property Inspector
- select 'Reset all properties'
This should make the layout the same as the default view for all breakpoints.
