why extra space bottom of page before header?
Markoc
Post by Markoc » Sun Jun 03, 2018 4:06 pm
Hi, Developing this index page using a masterframe and no matter what I try I cannot get rid of the extra space right above the footer. Could you help me figure the source? Thanks!
Here is the page:
http://www.ppocc.org//members2018test/index.php
Also noticed that my drop down my disappears when I scroll down the menu choices.
Also, there should be a javascript to have the copyright show in the footer but that is missing. Any idea?
I also had to add lots of padding to the top of my first layer grid so it wouldn't be hidden under the menu. Could that be the issue?
Thanks!
Re: why extra space bottom of page before header?
Post by Pablo » Sun Jun 03, 2018 4:25 pm
You are using layout grids in your page, so the height of the content is flexible based on the width of the viewport.
However, the footer has a fixed position. You will also need to make the footer floating.
Markoc
Post by Markoc » Sun Jun 03, 2018 4:28 pm
Thanks, that fixed my first issue.
I added the following issues after my first post.
Thanks!
Post by Pablo » Sun Jun 03, 2018 5:12 pm
Please try to focus on one thing at a time, this is very confusing
There seems to be something on top of the menu. Make sure menu is on top of everything, for erxample by using a pagde header set the 'in forn of content'
The text seems to be empty.
