About card breakpoint ***SOLVED***
ridvan
Post by ridvan » Mon Jun 04, 2018 11:36 am
Dear Pablo,
The card item doesn't save the different breakpoint in the flexible carousel. I mean, when I save it, it's seeing like as saved and small at the WYSIWYG web builder screen but it's seeing browser window not saved and very big.
Example,
1. Get a flexible carousel!
2. Add a card item in the carousel drag and drop. The font size you use the card is to be big. (For example 72 for a normal screen)
3. Then add different breakpoint (for example 320).
4. Change font size in the card. (Of course smaller).
Then check it on the browser window.
Re: About card breakpoint
Post by Pablo » Mon Jun 04, 2018 12:04 pm
Please share the project so I can see all your settings.
ridvan
Post by ridvan » Mon Jun 04, 2018 2:52 pm
I'm Sorry,
I've just started demo project today. Did you try my instruction? Is there a special setting? I think this is just being the flexible carousel. it's about just the flexible carousel. Because I added normal text middle of the carousel this time, it did the same thing. Later I'm going to share all my demo projects with other WYSIWYG web builder users. it can be useful.
Post by Pablo » Mon Jun 04, 2018 3:55 pm
I think this has already been fixed in the latest update (14.0.4)
The reason why I ask you for a demo project is because then I can also see all your other (project) settings.
This makes it easier and faster to help you.
