Multiples Layout grid in single form
vincen
Post by vincen » Sat Jul 21, 2018 6:05 am
Hello,
I would like to have one common form with several Layout Grid. This is for design reasons. I tried to insert One Layout Grid inside another Layout Grid, but editing becomes problematic (not possible to change alignment and in some cases elements may disappear).
Do you have a solution?
Thank you in advance
Vincent
Re: Multiples Layout grid in single form
Post by Pablo » Sat Jul 21, 2018 6:43 am
A form cannot be inside of a layout grid. A form uses absolute layout while the content of a layout grid must be flexible.
However, a layout gird itself can be a form -> 'Enable form'
vincen
Post by vincen » Sat Jul 21, 2018 6:54 am
Thanks for the answer,
I already use the Form option in the Layout Grid. But my problem is that the form elements are arranged on several Layout Grid.
If I enable the Form option on each Layoud Grid concerned, I will have several Forms on the same page and it will not be correct.
Post by Pablo » Sat Jul 21, 2018 10:47 am
Correct, only the main grid can have the form enabled. Forms cannot be nested.
