Layout grid padding query
mayur007
Post by mayur007 » Sat Jul 21, 2018 11:56 am
Hello
I need to know if layout grid has 2 sections then turned to mobile site then it its layout is up and down. 1st secrion u p2 nd down
When padding bottom is set then it effects only bottom section of the grid not upper section of the grid.
Is this a correct behaviour
Re: Layout grid padding query
Post by Pablo » Sat Jul 21, 2018 12:10 pm
You can set the padding for each column separately.
The padding of the grid itself only affects the top/bottom because horizontal padding is also use for the gutter.
mayur007
Post by mayur007 » Sat Jul 21, 2018 12:36 pm
So the section will not be affected in mobile view ,
Only top and bottom not respected to the sections correct
Thanx for the info
Post by Pablo » Sat Jul 21, 2018 1:13 pm
This is true for all views, not only 'mobile' view.
mayur007
Post by mayur007 » Sat Jul 21, 2018 5:12 pm
thq :D
