Responsive Blog Carousel
44MLB
Post by 44MLB » Sun Oct 14, 2018 5:19 pm
I have placed a blog carousel with the layout style “backgroundcover” in a layout grid (please see link below). Is it possible to make the carousel images scale in the same way as a normal image does in a Layout Grid? Or have I got the best out of it all ready?
While on the subject of the blog carousel. When I leave the “Button Text” empty, the button still exists! Is it possible to get rid of the unnecessary button?
http://www.ramsgatelifeboat.org.uk/test ... 10-18.html
Re: Responsive Blog Carousel
Post by Pablo » Sun Oct 14, 2018 5:21 pm
I'm sorry, there is no standard option for this.
No, the blog is driven by templates, the template layout is the same regardless of the selected properties.
But if you are an advanced user then you can create your own templates for the blog.
44MLB
Post by 44MLB » Sun Oct 14, 2018 5:44 pm
Hi Pablo,
Thanks for your response.
Unfortunately I'm just starting out on this project. So I guess the button will have to stay there for now.
Am I right in thinking the the Blog Carousel is the only carousel option for Layout Grids?
Post by Pablo » Sun Oct 14, 2018 6:01 pm
If you set the standard Carousel to 'flexible' then it can also be used in a layout grid.
Examples of flexible Carousels:
http://www.wysiwygwebbuilder.com/suppor ... ortal.html
http://www.wysiwygwebbuilder.com/suppor ... books.html
http://www.wysiwygwebbuilder.com/suppor ... asic7.html
http://www.wysiwygwebbuilder.com/suppor ... asic8.html
http://www.wysiwygwebbuilder.com/suppor ... sic10.html
44MLB
Post by 44MLB » Sun Oct 14, 2018 6:07 pm
Many thanks Pablo,
I will give this a try :D :D
