Website with No Grids?
StudentDonald
Post by StudentDonald » Tue Jul 16, 2019 4:52 pm
With all the hype and hoopla about the various grids, I thought I would give them a try with the end result being grid lock. Either too complicated and/or just not getting the control I want.
1.) So will a site with normal header/footer, content and breakpoints still work across the various browsers, OS's of today and the future?
2.) Is anyone still creating sites without a grid?
Thanks a lot!
Re: Website with No Grids?
Post by Pablo » Tue Jul 16, 2019 5:19 pm
yes
yes, it is just a different way of creating websites.
Related tutorial:
http://www.wysiwygwebbuilder.com/layout_modes.html
alan_sh
Post by alan_sh » Wed Jul 17, 2019 9:40 am
Thanks a lot!
I haven't used grids at all. I just create mulitple breakpoints. If you want to see one I've done, feel free to browse around here http://test.giantsseat.org.uk/ with a phone, tablet or PC and whatever browsers you want (it is still in test phase, so I can't guarantee that everything works).
Do let me know if you find any bugs/issues.
Alan
Nicolajazz
Post by Nicolajazz » Wed Jul 17, 2019 1:30 pm
I never used grid.
It appears to me that grids are good for single-page sites, home page or sites with few pages.
I need more control about layout so I continue to use the old breakpoints.
StudentDonald
Post by StudentDonald » Thu Jul 18, 2019 1:47 am
Thanks Pablo, Alan and Nicola
Alan, you are well on your way and smooth transitions with the break points. My 2 cents, when dragging the browser window smaller your menu bar goes to the top of the page with no margin/gap. On at least one page the text overlaps. On the activities page the font looks small. Old rule is 16-18 points for smartphones but that may have changed with the bigger phones. And I'm probably the last person who should be reviewing your site. So when your ready post it in the "Showcase your website ........................and invite feedback".
Best Regards
Post by crispy68 » Thu Jul 18, 2019 2:05 am
I never used grid.
I don't agree.
Just my 2 cents here but I use layout grids/floating layers more often than not and starting to infuse flexgrid into my designs more and more and I still use breakpoints when needed. I can't imagine myself going back to only just creating fixed sites with breakpoints. I know there is a bit more control in placing things where you want them but, with so many different screen widths out there, I like the fact that using grids makes it easier for the content to fit any size screen. I will admit, sometimes it takes some creativity or thinking outside of the box to get the desired look your are after. Keep in mind, if there is something that you cant achieve with a layout grid, you can still use a floating layer to put objects where you want them and still incorporate breakpoints. This allows you to still have a lot of control in creating a flexible layout. Keep practicing and it WILL get easier. :D
alan_sh
Post by alan_sh » Thu Jul 18, 2019 9:26 am
Best Regards
Thanks for the feedback. Which page has text overlapping?
As to the menus right at the top, that is deliberate. My feeling is that the user will use one particular size and not keep making their pages smaller and bigger. I also try smaller sizes on a smartphone/tablet and haven't noticed the text too small. But I will revisit the activities page.
Alan
bkjohns
Post by bkjohns » Thu Jul 18, 2019 4:15 pm
What Crispy68 said...once you get used to grids/flexbox you probably won't want to go back to straight breakpoints but you can still incorporate them into your designs.
StudentDonald
Post by StudentDonald » Thu Jul 18, 2019 4:39 pm
I’m going to reluctantly agree with crispy68 and bk, for the 2 sites I’m working on is mostly text with a few images. So I will give the grids another try. (Back to School)
(I have an I-phone 4s and a site using bootstrap looks fine. Another site uses CSS grids for the page content and it will not even load and locks up.)
Have some questions but I will start a new post for those.
Thanks everyone for your help!
