Do Inline Frames work in mobile devices?
Beth
Post by Beth »
Dear helpful friends:
May be a silly question, but do Inline frames work on mobile devices? It would be great if it worked and I can see many uses.
And, if so, what else does and doesn't work?
Thank you.
Re: Do Inline Frames work in mobile devices?
Inline frames is a standard HTML feature so it also works on mobile devices.
Note however that on Apple devices, frames are always full size to prevent a second scrollbar on the page.
WWB15 has a workaround for this (safari mobile fix)
Beth
Post by Beth »
Thank you Pablo for the fast and favorable reply!
