Different offset for bookmarks in the breakpoints
Bluesman
Re: Different offset for bookmarks in the breakpoints
Post by Bluesman » Tue Sep 10, 2019 1:51 pm
Siegbert wrote:
Tue Sep 10, 2019 5:15 am
Hello Bluesmann, so I did it too.
But I did not lock the bookmarks.
It was confusing to me that at 4 breakpoints I have 4 bookmarks, some of which are placed at default in the middle of the page. Is it correct that in the end I have to deactivate 3 objects at each breakpoint?
I think you overkill with having a new bookmark at every breakpoint. If you start with the "Default" viewport and place the bookmark at the right edge so you can move it seamless up or down without get it hooked by Layout grids etc. Then you go to next breakpoint and adjust the same bookmark in the same way so it works in this breakpoint... and for the rest... the bookmark will stay in their specific places. So you just nead one bookmark for each objekt/function.
"Make My Day"
See my Website
Siegbert
Post by Siegbert » Tue Sep 10, 2019 4:20 pm
Thank you.
I test it in the next days.
santieb
Post by santieb » Thu Jul 02, 2020 9:18 am
Hi
I struggle with the bookmarks. When i place the bookmark in the layout grid where my text and where i want it to display, it doesn't display exactly by the text. Its link from my navigation to the bookmark, but somehow it start where i want it to start. Any idea what i'm doing wrong?
Santie
Post by Pablo » Thu Jul 02, 2020 9:40 am
Related FAQ:
